Matrix Display – Max Size
Solved1.50K views17th December 2021Matrix
Diogo Silva [SLC] [DevOps Member]214 17th December 2021 0 Comments
What is max matrix (display) size supported?
Diogo Silva [SLC] [DevOps Member] Selected answer as best 17th December 2021
Jan Staelens [SLC] [DevOps Advocate]924 Posted 17th December 2021 1 Comment
We currently suggest sticking to a 1000X1000 sized matrix maximum when you’re using the Matrix UI Component. It’s not a hard limit, but this guarantees a fast and fluid functionality for heavy actions like bulk label adjustments or locks/unlocks.
Anything higher than this size, we would recommend instead to use regular tables and use the Routercontrol UI.
Diogo Silva [SLC] [DevOps Member] Edited comment 17th December 2021
Diogo Silva [SLC] [DevOps Member] commented 17th December 2021
As an extra note, there are issues automatically updating the Router Control with all required info if the matrix component is not implemented (already created a task a while ago but seems to not be fixed yet [https://collaboration.dataminer.services/task/147393]).
