Match with part of a string.
Solved2.07K views15th December 2023match Visio
Gerwin van der Kamp [DevOps Advocate]4.09K 14th December 2023 0 Comments
I've got an driver that returns an config string from an device. These strings look like this:
00010203
01010203
0C0D0E0F
etc, basically it comes down to added HEX values:
so it is device config string parameter 1 2 3 4 -> 00,01,02,03
now i want to show or hide a few shapes based on an parameter. paramer 1 for instance can be between 00-0f so i need to match the first two digits. For the second paramter i need to match the second set of two digits. and for the third parameter i need to match the 3th set etc.
How can i do this within an visio?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 15th December 2023
João Severino [SLC] [DevOps Enabler]14.78K Posted 14th December 2023 7 Comments
Hi Gerwin,
An option could be to use regex to parse the HEX values into each pair of digits.
In Visio, you can achieve this by using the option [RegexReplace:x,y,z] | DataMiner Docs
And then for the regular expression you can use ([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})
And then depending on the parameter you want you can use for the string that will replace each of the matches either $1 or $2 or $3 or $4 depending on whether you want the 1st, 2nd, 3rd, or 4th respectively.
Gerwin van der Kamp [DevOps Advocate] commented 15th December 2023
Hi i tried that, but i’m still getting the whole string back. I’ve got an shape with * as text and a Parameter shape data with the following:
[RegexReplace:[Sep:,%]([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})07,[cardvar:acp_slot]/#Emb1_Ch01/04%$1]
i figured i needed to use the Sep cause of the variable has an pid/key combo. However i still get the whole string back.
João Severino [SLC] [DevOps Enabler] commented 15th December 2023
Could you confirm if there is a typo in your comment? As I see 07, after the regex expression and only 1 %.
Additionally, could you try on a separate shape to have just the original input without using any placeholders? This could be helpful to verify if any other [Sep] are needed.
Re-reading your original question a doubt came to my mind.
Is your input 00010203 or does it contain ,? Like 00,01,02,03?
If it is the first then the original expression should work (https://regex101.com/r/nQN09b/1) otherwise if it should contain the , then you should use ([0-9a-fA-F]{2}),([0-9a-fA-F]{2}),([0-9a-fA-F]{2}),([0-9a-fA-F]{2}) (https://regex101.com/r/nQN09b/2)
There is a typo but i think it’s an html issue[RegexReplace:[Sep:,%]([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})07,[cardvar:acp_slot]/#Emb1_Ch01/04%$1]
so after the last ([0-9a-fA-F]{2}) there is an % 3007, (but without the space)
I try to access the paramter/displaykey: 3007,[cardvar:acp_slot]/#Emb1_Ch01/04 that’s why i did the Sep:,%
Could it be that you are missing a [param:] placeholder around the part where you try to access the parameter/displaykey?
Something like
[RegexReplace:[Sep:,%]([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})%[param:*,3007,[cardvar:acp_slot]/#Emb1_Ch01/04]%$1]
Show 2 more comments
