Low Code App not found while importing to Package Solution.
512 views27th November 2025#lowcodeapplication dataminer catalog lowcode app
Hamza Bashir [DevOps Advocate]52 14th November 2025 0 Comments
So I have created a Package Solution to deploy my low code App to catalog, when I try to import my existing low code app to package solution it give me error that
"Could not import App, failed to download low code app."
I am facing same error even I try to import any of dashboard as well. I am attaching screen shots of error as well.
Thanks in Advance!
Wim Bruynooghe [SLC] [DevOps Advocate] Answered question 14th November 2025
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 14th November 2025 0 Comments
Looks like you're getting an error page of https://dataminer.services.
Can you reach out to our support?
Wim Bruynooghe [SLC] [DevOps Advocate] Edited answer 27th November 2025
