LCAs Node Edge – Changing the color of a masked node
Solved1.87K views19th September 2024node-edge
Maria Cunha [SLC] [DevOps Advocate]433 1st July 2024 0 Comments
Hello Dojo community,
I am working on a node edge component, and I want the coloring mode to be "Alarm" but when my alarm is masked the color of the node is by default the color of the background, so I am not able to se the corresponding node.
Is it possible to change the icon color when the alarm related to that node is masked?
Maria Cunha [SLC] [DevOps Advocate] Selected answer as best 19th September 2024
Maria Cunha [SLC] [DevOps Advocate]433 Posted 2nd July 2024 1 Comment
Hello Ward,
I think that is not the solution for my problem.
When I have only one parameter related to that specific node masked, I can see the node (see image bellow)
But, if all parameters related to that node are masked the node icon changes to the color of the background (see image bellow).
So I think I cannot just filter by a specific parameter.
Kind regards
Gilles Bara [SLC] [DevOps Advocate] Edited comment 3rd July 2024
Gilles Bara [SLC] [DevOps Advocate] commented 3rd July 2024
The reason the icon “disappears” is because the color is actually applied on the background shape, not the icon. The icon takes a color that is in contrast with the background color. In the case of the masked color, this icon color will be white (the same as the component background). Could you please set a shape in the node config to verify this?
