LCA – Moving through IAS Panel
Solved498 views27th October 2025
Nejra Velic [SLC] [DevOps Member]424 17th October 2025 1 Comment
We have the following request from a user:
When pressing a button on LCA an interactive AS will be triggered which will open a popup window with some fields to fill in before hitting button Next to go on.
On that first popup there are boxes to fix on two sides (right and left, as you can see on image below):
Now, when filing in the fields, the user uses Tab on the keyboard. And once using Tab, it takes them from left to right (on the image that means filling in transmission title, then prepoll time, then title etc.). The user wishes to have this top to bottom (in this case transmission title, title, UMD etc.).
Is this something we can achieve in the LCA?
Thank you!
Nejra Velic [SLC] [DevOps Member] Selected answer as best 27th October 2025
Alija Kusur [SLC] [DevOps Advocate] commented 17th October 2025
Hi Nejra, this looks like the default web components behavior, rather than something LCA defined. However, I am looking forward to reading the other opinions on this.
Peter Vanpoucke [SLC] [DevOps Advocate]1.23K Posted 20th October 2025 0 Comments
Hi Nejra
Thanks for raising this! As Alija mentioned, the behavior you’re seeing is indeed the default.
To avoid this, a workaround could be to redesign the dialog so that it only contains a single column of input fields.
Alternatively, if restructuring the dialog isn’t feasible, it might be worth suggesting a new feature to add support for this functionality.
