LCA editor does not have option for import
Solved918 views14th August 2024LCA LCA Editor
Hari priya Venkatesan [DevOps Advocate]1.06K 29th July 2024 0 Comments
Hi Team,
The Low code app Editor(1.0.1 CU11) that i deployed does not have option for import. Is it not available in this version
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 14th August 2024
Arne Maes [SLC] [DevOps Member]886 Posted 7th August 2024 2 Comments
Hi
Indeed, the import button is no longer available in the latest versions. The latest version only exports as a .dmapp install package. Which you can install by double clicking the install package on the agent you want to install it too.
If you do not have RDP access to the agent you can use the client test tool.
  1. Connect using the Client Test Tool
  2. Go to Advanced -> Apps -> AppPackages...
  3. Click "Upload Package"
  4. Select the package created by the Low Code App Editor script
  5. Wait for it to upload the package to the agent
  6. Select the uploaded package
  7. Click the "Install Package" button
  8. [Optional] Remove the uploaded package again
Arne Maes [SLC] [DevOps Member] commented 7th August 2024
I have updated the README of the Low-Code-App-Editor’s GitHub repository to include these steps as well.
Hari priya Venkatesan [DevOps Advocate] commented 14th August 2024
Hi Arne,
Thanks for the response. Tried this and it was quite easy
