It is possible to avoid some notices alarms
Solved722 views20th February 2025alarm notices
7
Catarina Grilo [SLC] [DevOps Enabler]2.96K 20th February 2025 0 Comments
Is it possible to disable notice alarms from occurring?
In my case, when the DMS is restarted, there are always notices regarding the license: “Your DMA license is limited to 1000 elements. Currently you have 800 elements active”.
Since this is something I’m aware of, I don’t need this notice. Would it be possible to avoid them?
Catarina Grilo [SLC] [DevOps Enabler] Selected answer as best 20th February 2025
Danielle Falcone [SLC] [DevOps Advocate]1.49K Posted 20th February 2025 1 Comment
Hi Catarina,
I believe you can customize the notices by using WarningTreshold tag: DataMiner.xml | DataMiner Docs
I hope it helps,
kind regards,
Catarina Grilo [SLC] [DevOps Enabler] Posted new comment 20th February 2025
Catarina Grilo [SLC] [DevOps Enabler] commented 20th February 2025
Thank you!
