Issues setting up STaaS
Solved530 views25th June 2025
Nejra Velic [SLC] [DevOps Member]424 24th June 2025 0 Comments
I need to setup STaaS on a Staging server for a client. It is a single agent which needs to be linked, no failover. I've followed steps from the documentation on how to do the setup: Setting up STaaS | DataMiner Docs.
Steps 1,2 and 3 are ok (system is running version 10.4.12, connection do dataminer.services is green, the machine has internet access). Now on step 4 - upgrading DxM versions issues started appearing. I wanted to upgrade them to be able to get started with STaaS, but I see the error messages:
I followed the documentation on troubleshooting but still the issue persists:Investigating issues with dataminer.services features | DataMiner Docs.
All of the DataMiner services are running properly on Windows, no issues there. Also, I am now prevented to do any upgrades as you can see on the image below:
Does anyone know how to fix this issue?
Thank you in advance!
Nejra Velic [SLC] [DevOps Member] Selected answer as best 25th June 2025
Alexander Verkest [SLC] [DevOps Advocate]1.42K Posted 25th June 2025 1 Comment
This issue is unrelated to STaaS itself, but rather our system detecting that certain DxMs are not sending their heartbeat and as such are considered unhealthy. We prevent certain actions depending on which DxMs have this state, as we expect the actions to fail without a healthy DxM.
I recommend that you open a support request so that the logs can be analyzed and more tailored support can be given for this specific case.
Kind regards,
Nejra Velic [SLC] [DevOps Member] Posted new comment 25th June 2025
Nejra Velic [SLC] [DevOps Member] commented 25th June 2025
Hi Alexander,
Thank you for the explanation!
I will proceed as instructed.
