Issue Loading Logs on DataMiner Cube on New System
36 views10 hours agoCube Logging DM Cube
Micah Brown [SLC] [DevOps Advocate]368 10 hours ago 0 Comments
I can't load the logs remotely while the Auto Generated Certificate is configured on IIS and is in the "Trusted Root Certificates" folder of the DataMiner Agent. Is there something that needs to be adjusted on the web.config or something else that needs to be looked into?
Micah Brown [SLC] [DevOps Advocate] Asked question 10 hours ago
