Issue creating a single-run Scheduled Task: Code creates separate START and STOP tasks
Solved483 views12th December 2025#automationscripts Automation script Scheduler
Jan Palansky [DevOps Member]230 11th December 2025 0 Comments
I am trying to create an automation script that creates a scheduled task. The goal is to have this task trigger another script with a specific parameter. This task should run only once at a specific date and time.
I have based my code on the documentation here: https://docs.dataminer.services/develop/devguide/ClassLibrary/ClassLibraryScheduler.html
And I referenced the API types here: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.Scheduler.Automation.Scheduler.html
Here is the code I am using:
C#
var scheduler = new Scheduler(engine.GetUserConnection(), t => t != null);
        var scheduleOnce = new ScheduleOnce(createSchedulerEvent: true);
        var startTime = DateTime.Now.AddMinutes(1);
        var endTime = startTime.AddMinutes(1);
var paramsList = new List<AutomationScriptInputParameter>
            new AutomationScriptInputParameter(1, "Zacinam"),
        var scriptAction = new AutomationScriptAction("GIE", checkSets: true, runAsync: false, paramsList, Array.Empty<Skyline.DataMiner.Net.Messages.AutomationProtocolInfo>());
        var task = new Skyline.DataMiner.Core.Scheduler.Automation.SchedulerTask("TestScheduledRun", "Run Just Once", startTime, endTime, scheduleOnce, scriptAction);
scheduler.CreateOrUpdateSchedulerTask(task);
The Issue: I expected this to create a single task in the Scheduler named "TestScheduledRun". However, it creates two separate tasks:
  1. GIE - TestScheduledRun - START (runs at startTime)
  2. GIE - TestScheduledRun - STOP (runs at endTime)
My Question: How can I create a single task that executes only once at the defined time, without generating the secondary STOP task?
Any advice is appreciated. Thanks!
Jan Palansky [DevOps Member] Selected answer as best 12th December 2025
Robin Spruytte [SLC] [DevOps Advocate]783 Posted 11th December 2025 0 Comments
Hello Jan
Based on the documentation that you added, can you check if you can clear the 'schedulerTask.ISchedulerFinalAction' property. This action triggers when the end time is reached
A second option I'm considering is whether you could create the task without an endtime. Since you are trying to create a task that only executes once, there is no need for an endtime.
If both option do not work, you could create the tasks in an alternative way with the IDmsScheduler , which I believe does not have the same behaviour, even when adding endtime.
Robin Spruytte [SLC] [DevOps Advocate] Answered question 11th December 2025
