Issue creating a single-run Scheduled Task: Code creates separate START and STOP tasks
Solved477 views12th December 2025#automationscripts Automation script Scheduler
Jan Palansky [DevOps Member]230 11th December 2025 0 Comments
I am trying to create an automation script that creates a scheduled task. The goal is to have this task trigger another script with a specific parameter. This task should run only once at a specific date and time.
I have based my code on the documentation here: https://docs.dataminer.services/develop/devguide/ClassLibrary/ClassLibraryScheduler.html
And I referenced the API types here: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.Scheduler.Automation.Scheduler.html
Here is the code I am using:
C#
var scheduler = new Scheduler(engine.GetUserConnection(), t => t != null);
        var scheduleOnce = new ScheduleOnce(createSchedulerEvent: true);
        var startTime = DateTime.Now.AddMinutes(1);
        var endTime = startTime.AddMinutes(1);
var paramsList = new List<AutomationScriptInputParameter>
            new AutomationScriptInputParameter(1, "Zacinam"),
        var scriptAction = new AutomationScriptAction("GIE", checkSets: true, runAsync: false, paramsList, Array.Empty<Skyline.DataMiner.Net.Messages.AutomationProtocolInfo>());
        var task = new Skyline.DataMiner.Core.Scheduler.Automation.SchedulerTask("TestScheduledRun", "Run Just Once", startTime, endTime, scheduleOnce, scriptAction);
scheduler.CreateOrUpdateSchedulerTask(task);
The Issue: I expected this to create a single task in the Scheduler named "TestScheduledRun". However, it creates two separate tasks:
  1. GIE - TestScheduledRun - START (runs at startTime)
  2. GIE - TestScheduledRun - STOP (runs at endTime)
My Question: How can I create a single task that executes only once at the defined time, without generating the secondary STOP task?
Any advice is appreciated. Thanks!
Jan Palansky [DevOps Member] Selected answer as best 12th December 2025
Pieter Carlu [SLC] [DevOps Advocate]260 Posted 11th December 2025 1 Comment
Hi Jan,
This is because a scheduled task is created for each event (START and STOP), more information can be found here.
If you don't want to use the events and just have one scheduled task, you should change your script so that:
var scheduleOnce = new ScheduleOnce(createSchedulerEvent: false);
Hope this helps you further!
Kind regards,
Pieter
Jan Palansky [DevOps Member] commented 12th December 2025
thank you very much.
createSchedulerEvent: false works for me. This is exactly what I expected.
best regards
jan
Robin Spruytte [SLC] [DevOps Advocate]783 Posted 11th December 2025 0 Comments
Hello Jan
Based on the documentation that you added, can you check if you can clear the 'schedulerTask.ISchedulerFinalAction' property. This action triggers when the end time is reached
A second option I'm considering is whether you could create the task without an endtime. Since you are trying to create a task that only executes once, there is no need for an endtime.
If both option do not work, you could create the tasks in an alternative way with the IDmsScheduler , which I believe does not have the same behaviour, even when adding endtime.
Robin Spruytte [SLC] [DevOps Advocate] Answered question 11th December 2025
