Is there a way to overwrite decimal places of a column parameter
Solved2.25K views27th March 2023dynamicunits
Geovanny Galeano [SLC] [DevOps Advocate]800 5th July 2022 0 Comments
Our driver has some column parameters which some are metrics and other counters. Most metrics are using 3 or 4 decimals places while counters whole numbers. We want everything to have 4 decimals places since the data is aggregated by another tool which requires that structure of 4 decimals places. Is there a way to do this without affecting the core of the driver/other implementations? Something similar to DynamicUnits or applying and information template perhaps?
Geovanny Galeano [SLC] [DevOps Advocate] Selected answer as best 27th March 2023
Floris Cockaerts [SLC] [DevOps Member]2.43K Posted 6th July 2022 0 Comments
This depends on the parameter's <Interprete> definition, which can be different from the <Display> definition. For double type parameters, we round the amount of decimals to 6 by default, and this can be overwritten with the <Decimals> tag. Retrieving the parameter through NotifyProtocol or SLNet should yield this precision in the e.g. DoubleValue for SLNet's GetParameterResponseMessage.
I don't believe information templates are currently able to change the parameter's <Interprete> definition. Dynamic units only apply to the display representation of the value.
Floris Cockaerts [SLC] [DevOps Member] Answered question 6th July 2022
