Is there a way to convert CRC result in ASCII instead of hex?
Solved1.82K views2nd March 2023Connector crc serial protocol
7
Joachim Ally [SLC] [DevOps Advocate]1.64K 2nd March 2023 0 Comments
Dear Dojo Community,
Currently, I am developing a connector of the serial type.
Goal
In the documentation, the CRC check that is needed is explained like this:
There are also two examples included in the documentation, on which I indicated the CRC-part:
Current Code
What I tried to develop this was a CRC-param of type ‘exor’ and built the two sample messages:
  • The CRC-params:
  •   The commands:
Result
This did not get me the wanted result. It seems that I need an extra conversion to get the CRC-result in the format the device expects.
Workarounds
For the fixed commands that needs to be sent, I could hardcode the needed bytes. And for the responses, I could do a check via a QAction to verify if the response was correctly transmitted.
Question
Is there a way to achieve the wanted result without having to use this workarounds? I searched for an option in the documentation of the CRC-param, but did not find an option that could help me.
Joachim Ally [SLC] [DevOps Advocate] Selected answer as best 2nd March 2023
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 2nd March 2023 1 Comment
Hi Joachim, could you please try with <RawType>numeric text</RawType> instead of <RawType>unsigned number</RawType>. At the bottom of the following page, there is an example that does exactly what you want. There 6D is being converted to 0x3644 in the data.
https://docs.dataminer.services/develop/devguide/Connector/ConnectionsSerialCreatingCommandsAndResponses.html#cyclic-redundancy-check-crc
Joachim Ally [SLC] [DevOps Advocate] Posted new comment 2nd March 2023
Joachim Ally [SLC] [DevOps Advocate] commented 2nd March 2023
Hi Tom, thank you very much for the solution and the link to the detailed documentation page. I confirm that this worked for me. 🙂
