Is there a way to balance the load when selecting resources in SRM?
Solved2.13K views11th March 2021load-balancing resources SRM
Sebastian Ulloa [SLC] [DevOps Advocate]2.33K 10th March 2021 0 Comments
For a certain type of SRM pool X, we have ten resources available. However, the bookings get assigned to the same resources every time. For example, if three bookings are received without conflicts, each with one hour apart, they are most likely to use the same resource from pool X.
This scenario is causing some issues because if we want to extend one of the bookings by two hours, it would not be possible because the resource of pool X is already booked. Because of this, I wonder if it is possible to ask SRM to assign resources in a balanced way? so in the example, if three bookings are received each one will get booked with different resources of pool X.
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 11th March 2021
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 11th March 2021 0 Comments
Sebastian,
You can go to the Config>Wizard tab and set the Resources Ordering Rule to 'Random'. This will randomize the selection of the resource.
Another option it to make use of the guard interval features; however this will require more processing in the background.
