Interactive automation script, how to display a clickable hyperlink?
Solved1.20K views22nd November 2024interactive automation script
Dieter Pappens [SLC] [DevOps Member]618 21st November 2024 0 Comments
I’m working on an interactive automation script and want to display a clickable hyperlink in the interface. I noticed the Label widget has a DebugTag property, which seems related to rendering raw HTML. Can I use this property (or another approach) to display a clickable hyperlink? If so, how?
Dieter Pappens [SLC] [DevOps Member] Selected answer as best 22nd November 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 21st November 2024 1 Comment
Hi Dieter,
You could try using UIBlockType.Executable or UIBlockType.DownloadButton.
See the following similar questions:
  • https://community.dataminer.services/question/how-to-open-a-hyperlink-from-an-ias-via-low-code-app/
  • https://community.dataminer.services/question/hyperlink-in-interactive-automation-script/
DebugTag serves a different purpose and is not applicable in this case.
Dieter Pappens [SLC] [DevOps Member] Edited comment 22nd November 2024
Dieter Pappens [SLC] [DevOps Member] commented 22nd November 2024
Thank you for your help, Tom!
Using the questions you provided, I successfully located the download button in the IAS toolkit. Here's the code snippet I used to set it up:
downloadButton = new DownloadButton()
Text = "Title",
RemoteFilePath = "https://skyline.be",
StartDownloadImmediately = false,
DownloadedFileName = string.Empty,
This implementation worked perfectly for my needs.
