Integrated a BUC on an uplink antenna
Solved1.66K views9th December 2020
Mark Woodyatt [DevOps Advocate]515 8th December 2020 0 Comments
Hello All,
Has anyone integrated a BUC (outboard uplink system on the back on an antenna) into DM please?
Was this difficult?
Are MIBs etc available to do this?
Was DM the only control?
Thank you.
Mark
Mark Woodyatt [DevOps Advocate] Selected answer as best 9th December 2020
Koen Cools [SLC] [DevOps Member]331 Posted 8th December 2020 2 Comments
Hi Mark, We integrated already multiple block up converters for different projects, this is typically a straight forward integration. Feel free to share your device type with your sales or technical Skyline contact so that we can verify if we have already a protocol driver or not.
Mark Woodyatt [DevOps Advocate] commented 8th December 2020
Thanks Koen! Will do.
Koen Cools [SLC] [DevOps Member] commented 8th December 2020
Hi Mark, you can also use our catalog (https://catalog.dataminer.services/) to verify if there was already an integration for your device.
