IDP changing to DOM and LCA
Solved593 views28th August 2025DOM IDP low code app
6
Dave Keller [DevOps Enabler]1.95K 30th July 2025 0 Comments
Are there any active plans to move IDP towards DOM and LCA?
We are considering adding the current IDP to our DMS and populating it with data, but we are wondering if this would be futile if an IDP replacement is around the corner.
Dave Keller [DevOps Enabler] Selected answer as best 28th August 2025
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.53K Posted 20th August 2025 0 Comments
There are currently no plans to move to DOM. While a low-code application (LCA) would introduce an additional UI layer, it would still rely on the existing IDP back-end. The LCA would be embedded within the current IDP visual Overview, ensuring that Cube users can continue to access it in the usual way.
At this point, a transition to an LCA is more likely than a move to DOM. However, it's important to note that no specific plans or timelines have been established for this transition.
