IAS throws DataMinerException and not ScriptTimeoutException when reaches timeout
Solved1.28K views10th February 2025exception handling interactive automation script
Vasco Coelho [SLC] [DevOps Member]66 31st January 2025 0 Comments
When an interactive automation script reaches a timeout, it throws a DataMinerException instead of a ScriptTimeoutException. Why does this occur?
I would expect a ScriptTimeoutException to be thrown, as this would allow for a more customized dialog message instead of the generic 'Automation script aborted'.
Vasco Coelho [SLC] [DevOps Member] Selected answer as best 10th February 2025
Peter Vanpoucke [SLC] [DevOps Advocate]1.24K Posted 3rd February 2025 0 Comments
hi Vasco
In case a script times out, when a UI is shown, a DataMinerException will be thrown indeed.
I'm afraid thought that, even when the exception is correctly catched, it won't be possible to show a new dialog within the same script execution. Since the execution timed out, interaction with engine is limited.
