How to trigger one automation script from other automation script ?
Solved1.88K views26th April 2021Automation script C++
Niraj Deval42 26th April 2021 0 Comments
  1. automationScript1 with 2 parameter
  2. automationScript2
how to trigger automationScript1 with parameters from automationScript2 in c# scripting?
Niraj Deval Selected answer as best 26th April 2021
João Severino [SLC] [DevOps Enabler]14.49K Posted 26th April 2021 0 Comments
From automation script 2 you can use subscript = engine.PrepareSubscript (ref to Help) which will return a SubScriptOptions object
You can then use this object and call subscript.SelectScriptParam (ref to Help) before calling the StartScript method as illustrated in the example available on the first link help page
In the end you should have something like this
var subscript = engine.PrepareSubScript("MySubscript");
subscript.SelectScriptParam("myScriptParam1", "myValue1");
subscript.SelectScriptParam("myScriptParam2", "myValue2");
subscript.StartScript();
