How to solve DataMinerSecurityException: No such remote connection, when script starts from QAction?
Solved1.78K views3rd May 2024Automation Script DOM dataminer connection domhelper exception QAction
Michiel Clepkens [SLC] [DevOps Advocate]1.51K 30th April 2024 0 Comments
Hi Dojo
It seems that I’m not able to run an automation script that was launched from a QAction without user interaction.
A web service sets the value of a specific parameter. The value change of that parameter triggers a QAction which launches the automation script. This works fine up until the point where an interaction is needed with the DomHelper class. At that point, a DataMinerSecurityException is thrown. The stack trace is listed down below. Skyline.DataMiner.Net.Exceptions.DataMinerSecurityException: No such remote connection (17fd22f11d). Retried.
Element log
protocol.UserCookie 17FD22F11DDA4B7C8D00DF7CD9C76CF9
protocol.UserInfo Admin
(protocol.GetUserConnection() throws a DataMinerSecurityException: No such remote connection)
Script log
engine.UserLoginName (Script ‘Set Request Status’)
engine.UserDisplayName Unknown User
engine.UserCookie 17FD22F11DDA4B7C8D00DF7CD9C76CF9
On the other hand, if that automation script gets launched by pressing a button on the element, it executes without any issues.
Element log
protocol.UserCookie 202B80721E6A4BB39E352BCE3D2609CA
protocol.UserInfo MCS
protocol.GetUserConnection().ConnectionID 202b8072-1e6a-4bb3-9e35-2bce3d2609ca
Script log
engine.GetUserConnection().ConnectionID 202b8072-1e6a-4bb3-9e35-2bce3d2609ca
engine.UserLoginName SkylineMCS
engine.UserDisplayName MCS
engine.UserCookie 202B80721E6A4BB39E352BCE3D2609CA
How can I make sure a valid connection gets established to run the script successfully in both cases?
Thank you in advance!
Kind regards
Server stack trace:
at Skyline.DataMiner.Net.Facade.HandleImpersonateMessage(IConnectionInfo originalConnInfo, ImpersonateMessage im)
at Skyline.DataMiner.Net.Facade.HandleMessageInternal(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.Facade.HandleMessage(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.BaseFacade.HandleMessages(IConnectionInfo connInfo, DMSMessage[] msgs)
at Skyline.DataMiner.Net.Facade.HandleMessagesForClient(IConnectionInfo connInfo, DMSMessage[] messages)
at Skyline.DataMiner.Net.Transport.Remoting.InternalHandleMessages(ConnectionToken token, DMSMessage[] inputMessages, ConnectionTransportType ctt)
at Skyline.DataMiner.Net.Transport.Remoting.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages, ConnectionTransportType ctt)
at Skyline.DataMiner.Net.Transport.Remoting.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Skyline.DataMiner.Net.ISLNet.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
at Skyline.DataMiner.Net.LegacyRemotingConnection.TransportSpecificHandleMessage(ConnectionToken tok, DMSMessage[] msgs, Int32 timeout)
at Skyline.DataMiner.Net.Connection.InternalHandlePackedMessages(ConnectionToken tok, DMSMessage[] msgs, Int32 timeout)
at Skyline.DataMiner.Net.Connection.InternalHandleUnpackedMessages(DMSMessage[] msgs, Int32 timeout)
at Skyline.DataMiner.Net.Connection.HandleMessages(DMSMessage[] msgs, Int32 timeout)
at Skyline.DataMiner.Net.PersistentConnectionContainer.SendMessages(DMSMessage[] messages)
at Skyline.DataMiner.Automation.Engine.SendSLNetMessages(DMSMessage[] messages)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.<>c__DisplayClass45_0.<WrapWithExtraInfoInjection>b__0(DMSMessage[] messages)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.RetrieveResponse(DMSMessage request)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.RetrieveResponse[TResp](DMSMessage request)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.RetrieveCrudResponse(DMSMessage request)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.InnerRead(IQuery`1 query, IAdditionalOperationMeta operationMeta)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.Read(IQuery`1 query)
at Skyline.DataMiner.Net.ManagerStore.CrudHelperComponent`1.Read(FilterElement`1 filter)
at Set_Request_Status_1.Script.Run(Engine engine) (Script ‘Set Request Status’)
Michiel Clepkens [SLC] [DevOps Advocate] Selected answer as best 3rd May 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 2nd May 2024 2 Comments
Hi Michiel,
Are you passing the user cookie from the QAction to the automation script? If not, you could try executing your script as follows:
var dms = protocol.GetDms();
var parameters = Enumerable.Empty<DmsAutomationScriptParamValue>();
var dummies = Enumerable.Empty<DmsAutomationScriptDummyValue>();
dms.GetScript(“My Script”).Execute(parameters, dummies, userCookie: protocol.UserCookie);
If that still doesn’t work you could maybe try to use the static Engine.SLNetRaw property when setting up the DomHelper instance in your script.
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 3rd May 2024
Michiel Clepkens [SLC] [DevOps Advocate] commented 3rd May 2024
Hi Tom. Thank you very much for checking the question. I was able to make it work by passing the Engine.SLNetRaw.SendAsyncOverConnection delegate to the constructor of the DomHelper class in the script: DomHelper domHelper = new DomHelper(Engine.SLNetRaw.SendAsyncOverConnection, moduleId); Thanks for the tip! Much appreciated!
Tom Waterbley [SLC] [DevOps Enabler] commented 3rd May 2024
Great, glad to hear the problem is resolved!
