How to run a .bat from an automation script ?
Solved1.96K views2nd July 2024Automation script
Bernard Pichot [SLC] [DevOps Advocate]1.48K 2nd July 2024 0 Comments
I try to launch a Windows .bat file from an automation script. I found an example below on Internet but it doesn’t work from the automation script.
Do you have any any how to launch a .bat in silent mode ?
using System;
using System.Diagnostics;
public class Script
string batch = @”C:\Skyline DataMiner\Documents\DMA_COMMON_DOCUMENTS\myscript.bat”;
string parameters = $”/c \”{batch}\””;
Process.Start(<span class="hljs-string">@"C:\windows\system32\cmd.exe"</span>, parameters);
Bernard Pichot [SLC] [DevOps Advocate] Selected answer as best 2nd July 2024
Tom Waterbley [SLC] [DevOps Enabler]10.36K Posted 2nd July 2024 1 Comment
Hi Berard,
The problem could be the usage of \ in the command arguments. Maybe try something like this:
var startInfo = new ProcessStartInfo
WorkingDirectory = @”C:\Skyline DataMiner\Documents\DMA_COMMON_DOCUMENTS”,
FileName = @”C:\Windows\System32\cmd.exe”,
Arguments = @”/c “”myscript.bat”””,
CreateNoWindow = true,
Process.Start(startInfo);
Another option is to escape the command line arguments: https://stackoverflow.com/questions/5510343/escape-command-line-arguments-in-c-sharp
Bernard Pichot [SLC] [DevOps Advocate] Posted new comment 2nd July 2024
Bernard Pichot [SLC] [DevOps Advocate] commented 2nd July 2024
It works fine, Thanks a lot Tom
