How to retrieve SNS topic notifications into Dataminer using AWS cloudwatch connector
163 views10th March 2026AWS Cloudwatch connector AWS SNS role based authentication SNS to Http
Srimathi Ramachandran [DevOps Member]198 10th March 2026 0 Comments
Hello ,
I am trying to receive Amazon CloudWatch metrics notifications in DataMiner using the AWS CloudWatch Connector.
My idea is to configure AWS SNS to send notifications to an HTTP/HTTPS endpoint that points to the DataMiner server.
Before implementing this, I would like to understand a few things:
  • Are there any prerequisites or limitations when using the AWS CloudWatch Connector to receive SNS notifications?
  • Is there anything special that needs to be configured when adding the DataMiner server as an HTTP/HTTPS endpoint in SNS?
  • Does the connector expect a specific payload format for SNS notifications?
  • If we want to use role-based authentication (IAM roles), what is the recommended way to configure it?
I would appreciate any guidance on this 🙂 Thanks
Srimathi Ramachandran [DevOps Member] Asked question 10th March 2026
