How to read selected data from booking wizard in profileLoadScript?
Solved3.47K views10th December 2020process automation SRM
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 10th December 2020 0 Comments
How to get the data written by user in wizard in profile load script of an activity running in Process Automation.
The Default instance has the following data:
In the profile load I would like to get the "Stop" value as event type as this is what I selected in the wizard.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 10th December 2020
João Severino [SLC] [DevOps Enabler]14.78K Posted 10th December 2020 0 Comments
Hi Mieke,
Process Automation behaves slightly different from “regular” SRM and I do believe you need to always use the “By Reference” option.
Which means you must have a different Profile Instance for your “Stop” value.
