How to read selected data from booking wizard in profileLoadScript?
Solved3.50K views10th December 2020process automation SRM
Mieke Dryepondt [SLC] [DevOps Advocate]4.24K 10th December 2020 0 Comments
How to get the data written by user in wizard in profile load script of an activity running in Process Automation.
The Default instance has the following data:
In the profile load I would like to get the "Stop" value as event type as this is what I selected in the wizard.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 10th December 2020
Robin Meurisse [SLC] [DevOps Advocate]1.51K Posted 10th December 2020 3 Comments
As the input is coming from the Booking wizard rather then the passed volatile profile instances, there is another way to read the actual values from the booking wizard:
1. Your automation script should receive as input 3 values: "Info", "ProfileInstance" and "ProcessInfo".
2. Deserialize the input "Info" to have a SrmResourceConfigurationInfo object and the input "ProfileInstance" to have a Dictionary containing all the profile instances.
3. Create a new instance of ProfileParameterEntryHelper(Engine engine) and collect all the parameters with .GetNodeProfileParameterEntries().
I've included a small code snipped that should let you receive the list of parameters with the values you've specified in the booking wizard.
ScriptParam paramInfo = engine.GetScriptParam("Info");
ScriptParam paramProfileInstance = engine.GetScriptParam("ProfileInstance");
ScriptParam paramProcessInfo = engine.GetScriptParam("ProcessInfo");
var srmInfo = JsonConvert.DeserializeObject<SrmResourceConfigurationInfo>(paramInfo.Value);
if (srmInfo == null)
throw new ScriptInputValueNullException("SRM Info is null or is not in the correct format (Serialize SrmResourceConfigurationInfo to JSON).");
var srmNodeProfileConfiguration = JsonConvert.DeserializeObject<Dictionary<string, Guid>>(paramProfileInstance.Value);
if (srmNodeProfileConfiguration == null || !srmNodeProfileConfiguration.Any())
throw new ScriptInputValueNullException("ProfileInstance is null or is not in the correct format (Serialize Dictionary<string, string> to JSON).");
var helper = new ProfileParameterEntryHelper(engine);
List<ProfileParameterEntry> parameters = helper.GetNodeProfileParameterEntries(srmInfo, new NodeProfileConfiguration(srmNodeProfileConfiguration), true).ToList();
Robin Meurisse [SLC] [DevOps Advocate] Posted new comment 10th December 2020
Mieke Dryepondt [SLC] [DevOps Advocate] commented 10th December 2020
Hello Robin,
I’ve tried this, but it gets the default value that is filled in the profile instance definition. In this example = “Start”
I’ve also tried this witht he same result:
helper.GetNodeSrmParametersConfiguration(configurationInfo, nodeProfileConfiguration).ToList();
João Severino [SLC] [DevOps Enabler] commented 10th December 2020
Hi Mieke,
Process Automation behaves slightly different from “regular” SRM and I do believe you need to always use the “By Reference” option.
Which means you must have a different Profile Instance for your “Stop” value.
Robin Meurisse [SLC] [DevOps Advocate] commented 10th December 2020
After a quick test, Process automation indeed takes the reference value. The solution then would be to create a new Profile Instance with the new value like João mentioned.
My code snippet can then be ignored as it not applicable for process automation.
