How to package an low code app + dom module
Solved2.76K views29th March 2024dmapp LCA package
Gerwin van der Kamp [DevOps Advocate]4.09K 29th March 2024 0 Comments
I'm currently working on some low code apps and dom modules. Now i need to package those and install them into production.
  1. is there way to but an low code app / application folder on a git and package it from there including the dom structure?
  2. is there an other way to build the package from the agent itself?
Looking at : https://community.dataminer.services/enhance-your-ci-cd-pipeline-with-dataminer-net-tools/ and https://www.nuget.org/packages/Skyline.DataMiner.CICD.Tools.Packager#readme-body-tab
It works for dashboards visios etc but not applications.
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 29th March 2024
Frederic Anthierens [SLC] [DevOps Advocate]326 Posted 29th March 2024 0 Comments
Hi Gerwin,
I use the interactive automation script in the following GitHub repository to export a low code apps: https://github.com/SkylineCommunications/Low-Code-App-Extensions. In the later versions of the script, I believe DOM is included as well. The script generates a package which can installed via the Client test tool.
