How to package an low code app + dom module
Solved2.81K views29th March 2024dmapp LCA package
Gerwin van der Kamp [DevOps Advocate]4.09K 29th March 2024 0 Comments
I'm currently working on some low code apps and dom modules. Now i need to package those and install them into production.
  1. is there way to but an low code app / application folder on a git and package it from there including the dom structure?
  2. is there an other way to build the package from the agent itself?
Looking at : https://community.dataminer.services/enhance-your-ci-cd-pipeline-with-dataminer-net-tools/ and https://www.nuget.org/packages/Skyline.DataMiner.CICD.Tools.Packager#readme-body-tab
It works for dashboards visios etc but not applications.
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 29th March 2024
Matthijs Favorel [SLC] [DevOps Advocate]2.64K Posted 29th March 2024 1 Comment
Hi Gerwin,
To package a low-code app, you can use the CompanionFiles folder, like it is used for example in this repo.
To automatically deploy a DOM structure, you will need to programmatically create it in the install script of a package. (Or in a separate script that is launched as a subscript in the install script)
Gerwin van der Kamp [DevOps Advocate] Posted new comment 29th March 2024
Gerwin van der Kamp [DevOps Advocate] commented 29th March 2024
Do you happen to have some examples for this as well?
