How to keep a variable in memory between automation script runs?
Solved1.46K views12th July 2024automation scipt Memory
Mieke Dryepondt [SLC] [DevOps Advocate]3.91K 11th July 2024 0 Comments
With connectors - qactions it is possible to keep a variable in memory between 2 executions of the qaction.
This is also possible for ad-hoc datasources.
How can we do this for Automation scripts?
And when there is no built-in mechanism by DataMiner, could this still be accomplished somehow?
E.g. a static concurrent (thread-safe) dictionary or something alike
Tom Waterbley [SLC] [DevOps Enabler] Answered question 12th July 2024
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 12th July 2024 0 Comments
Hi Mieke, in automation scripts you can also use the same method to store data in memory as in QActions. Static fields and properties of classes are kept in memory during the lifetime of the SLAutomation process. When the process restarts, that data will be gone. This is a great way though to cache data that can easily be retrieved back after a DMA restart.
