how to include default templates folder from solution connector to .dmprotocol package
Solved1.14K views21st November 2024alarmtemplate DMProtocol publish Templates trend
Chirangee lal Verma [DevOps Advocate]555 5th November 2024 1 Comment
I have developed a solution connector and uploaded it into a private catalog. I also need to include alarm and trend templates with this solution connector so that users can access them when they deploy from the catalog. To achieve this, I have uploaded these templates into the default templates folder and rename these files as mentioned in about.md file. However, users are not receiving these templates when deploying the connector.
From what I understand, the issue might be that the .dmprotocol packager command is not considering this folder during creation. Could this be the problem, or is there something else I might be missing?
Chirangee lal Verma [DevOps Advocate] Selected answer as best 21st November 2024
Chirangee lal Verma [DevOps Advocate] commented 6th November 2024
I get to know that by this method I can include alarm and trend template with protocol while publishing into private catalog.
Avatar photo
Jan Staelens [SLC] [DevOps Advocate]924 Posted 21st November 2024 3 Comments
Hello,
We’ve reviewed this and identified it as a missing functionality in the current DevOps tools for connectors. Our legacy internal tooling included this feature, which is why the documentation and folders are present in the connector solution template in Visual Studio.
At the moment, there’s no viable alternative for the wider community using the DevOps tools, other than manually installing the templates afterward. Given the importance of this, we’ve prioritized it and will aim to add this functionality in the next few weeks.
Thank you for bringing this to our attention and for your patience.
Chirangee lal Verma [DevOps Advocate] Posted new comment 13th December 2024
Chirangee lal Verma [DevOps Advocate] commented 21st November 2024
thanks for you reply
Avatar photo
Jan Staelens [SLC] [DevOps Advocate] commented 3rd December 2024
Hello,
We’re excited to announce a new version of the packager! This update now includes any configured default alarm and trend templates with your .dmprotocol.
You can find the updated version here: https://www.nuget.org/packages/Skyline.DataMiner.CICD.Tools.Packager/2.0.7
Thank you for reporting the issue!
Kind regards
Chirangee lal Verma [DevOps Advocate] commented 13th December 2024
Thanks, Jan for your comments.
