How to force sync a failover system
Solved3.41K views24th November 2020Failover synchronization
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K 10th November 2020 0 Comments
A backup agent is not in sync with a running (and live) main agent.
How can we force a sync so the backup is OK again?
The midnight sync does not solve it. And using the System Center > Tools > Sync > "this dms" does not seem to do anything (no info events are generated)
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 24th November 2020
Luis Terrazas [SLC] [DevOps Member]150 Posted 11th November 2020 3 Comments
Which components of the DMA aren't in sync? Is it the DB or something else within the DMA (elements, views, protocols)? What DM version is it?
Mieke Dryepondt [SLC] [DevOps Advocate] commented 12th November 2020
The element and protocol files are missing.
When a switch is done none of the elements are shown.
When we check the Status page via system center on the running main the failover is indicated OK.
Alexander Gudkov [SLC] commented 16th November 2020
Hi Mieke,
You will need to use SLNetClientTest tool and do “Forcing file synchronization between DMAs” with the selected flag “Fix inconsistency problems”. You can find the details in the DataMiner help: Reference -> Tools -> SLNetClientTest tool -> SLNetClientTest tool advanced procedures: Forcing file synchronization between DMAs.
Mieke Dryepondt [SLC] [DevOps Advocate] commented 17th November 2020
Thanks Alexander.
I could use the force sync dma, but this not sync the missing Elements + Protocols.
I found that we can set all files from a folder as changed via the same tool, but how can I make sure that all the sub folders are also “forced” to sync?
