How to force sync a failover system
Solved3.41K views24th November 2020Failover synchronization
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K 10th November 2020 0 Comments
A backup agent is not in sync with a running (and live) main agent.
How can we force a sync so the backup is OK again?
The midnight sync does not solve it. And using the System Center > Tools > Sync > "this dms" does not seem to do anything (no info events are generated)
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 24th November 2020
Jelle Hoorne [SLC] [DevOps Member]366 Posted 10th November 2020 1 Comment
Hi Mieke,
When you say the backup agent is not in sync, does this mean that when you perform a 'nodetool status' on the offline agent the effective ownership of that node is less then 100% or what exactly makes you say the agents are not in sync i.e. are files not in sync or is the database not in sync?
If the database would be out of sync, performing a 'nodetool repair' should make sure all data gets synced again between the two nodes.
Alexander Gudkov [SLC] Posted new comment 10th November 2020
Alexander Gudkov [SLC] commented 10th November 2020
It can also make sense to do the compaction after the repair process finished. Run the ‘nodetool compact -s’ on both agents to start the compaction manually (in case if the database is more than 10 GB compact the tables separately)
