How to force release ownership in alarm in automation script if its not system?
Solved707 views8th May 2025
Apurva Tandon [DevOps Advocate]1.73K 2nd May 2025 0 Comments
In the automation script, I want to get the current owner with respect to alarm and then if its not system, release that?
Apurva Tandon [DevOps Advocate] Selected answer as best 8th May 2025
Pieter Carlu [SLC] [DevOps Advocate]260 Posted 6th May 2025 0 Comments
You can do this by sending the following SLNet messages:
