How to fix browser timezone display in low code app?
Solved1.23K views11th December 2024#lowcodeapp localtime low code app timezone
Alexandre Bonnet [DevOps Advocate]469 10th December 2024 0 Comments
Hello Dojo,
I’m encountering a timezone issue with my extranet application.
When I use it in France, it correctly displays French time, and I’ve added local time for example for Reunion by calculating the local time difference.
However, when a colleague accesses the application from Reunion, their browser appears to apply their local timezone offset to all displayed times.
I need to find a solution where they can see the same times as us without having to modify their browser or system settings.
Best regards,
Alexandre
Alexandre Bonnet [DevOps Advocate] Selected answer as best 11th December 2024
Matthijs Favorel [SLC] [DevOps Advocate]2.63K Posted 10th December 2024 1 Comment
Hi  Alexandre,
The server can force the timezone of the clients if you set this up in the ClientSettings.json file, see more info in the documentation.
Note that this will be applied to all Dashboards and Low Code Apps.
Alexandre Bonnet [DevOps Advocate] commented 11th December 2024
Hello Matthijs,
Thanks a lot for your answer i'm gonna try that !
