How to filter DOM Instances based on String Field using Regex
Solved538 views29th December 2025dom filter Regex
8
Thomas Remmery [SLC] [DevOps Advocate]957 23rd December 2025 0 Comments
Hi, I'm trying to retrieve DOM instances that contain a string field matching a certain regex. So far, this is what I got:
  • DomInstanceExposers.FieldValues.StringField(FieldDescriptorID.Id.ToString()).Matches(".*");
But this doesn't seem to return anything even though all instances on my agent have that string field defined and contain a value. Any idea how I can achieve this?
Thomas Remmery [SLC] [DevOps Advocate] Selected answer as best 29th December 2025
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.75K Posted 26th December 2025 1 Comment
Hi Thomas,
Using regex filters on DOM field values is unfortunately currently not supported. There is a docs page that notes all officially supported filter operators: https://docs.dataminer.services/dataminer/Functions/DOM/DomHelper_class.html#filtering
Feel free to share any use-case where this would be used and create a feature request. Our team can then investigate whether it will technically be possible to add this functionality.
Thomas Remmery [SLC] [DevOps Advocate] Posted new comment 29th December 2025
Thomas Remmery [SLC] [DevOps Advocate] commented 29th December 2025
Hi Thomas, thanks for the answer. I was able to work around it by using the .Contains() instead.
