How to delete through context menu in automation
Solved1.44K views2nd August 2024Automation context menu
Gerwin van der Kamp [DevOps Advocate]4.09K 2nd August 2024 0 Comments
I'm working on a LCA which needs to be able to add items to an table in an connector through an context menu. I've seen this example: https://community.dataminer.services/question/automation-script-context-menu/?hilite=context+automation
and i'm currently working on an script as POC. However i ran into an issue where i try to delete an item through with the automation script
with this information: https://docs.dataminer.services/develop/api/NotifyTypes/NT_ALL_TRAP_INFO.html it says i should pass the additional data. However what is the additional data for deletion? Is that the guid of the row i want to delete?
I'll try to get the interapp calls on the connector as improvement but for now i'll have to work through the context menu.
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 2nd August 2024
João Severino [SLC] [DevOps Enabler]14.91K Posted 2nd August 2024 1 Comment
Hi Gerwin,
When the context menu contains the option options="table:selection", it will pass along all the selected primary keys to the logic behind it.
You should be able to do the same within your code.
Gerwin van der Kamp [DevOps Advocate] commented 2nd August 2024
Thanks i’ll give it a try 🙂
