How to correctly format multipart/form-data request body for HTTP session
Solved5.13K views29th August 2023HTPP Multipart/from-data
Julian Yepe [SLC] [DevOps Member]316 15th August 2023 0 Comments
I am trying to send a POST HTTP request with Content-Type=multipart/form-data and I keep getting this error response: (status code: HTTP/1.1 400 Bad Request), returned VT_BSTR : {"errors": [{"message": "Multipart Request should be correctly formatted (1=name, 2=key)"}]}.
I have added screenshots from what the request payload and request headers look like when ran from swagger editor, screenshot of the HTTP session i have defined in the protocol.xml, and a screenshot of the of the request being logged by the element. Does anyone know what the issue could be?
Julian Yepe [SLC] [DevOps Member] Selected answer as best 29th August 2023
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 16th August 2023 0 Comments
Hi Julian,
As an extra side note, you should let DataMiner add and calculate the Content-Length header instead of hard-coding it in the connector.
Simon Vandamme [SLC] [DevOps Advocate] Answered question 16th August 2023
