How to allow the same automation script to run Non-Interactive and Interactive flows?
Solved1.91K views4th April 2024automation scipt
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 3rd April 2024 0 Comments
Hi, I would like to create a generic script that will based on calculation (logic) determine if an interactive screen needs to be shown or just execute.
How do I accomplish this?
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 4th April 2024
Michiel Clepkens [SLC] [DevOps Advocate]1.50K Posted 3rd April 2024 2 Comments
Hi Mieke
Your question looks similar to this question created by Gilles: Using same automation script in interactive and non-interactive mode - DataMiner Dojo
Does this help you out?
Kind regards
Gilles Vanhee [SLC] [DevOps Member] Posted new comment 3rd April 2024
Mieke Dryepondt [SLC] [DevOps Advocate] commented 3rd April 2024
Not really. I’m not sure what is meant with “just skip”.
Does this mean that I can have a simple if-statement:
If (interactionNeeded)
// Show screen
else
// Execute
Because when I do this via Cube Editor, I always get “Interaction required” error when running the flow that doesn’t need to show the screen.
Would this mean there is a SW bug?
Gilles Vanhee [SLC] [DevOps Member] commented 3rd April 2024
Hi, in this script (https://github.com/SkylineCommunications/SLC-AS-SetElementCustomProperty) we are combining interactive and non-interactive mode. An if-statement should do the trick.
Did a test via the cube editor and it works fine at our end.
