How to add an existing element to an additional View through code?
Solved319 views19th November 2025QActions
Mieke Dryepondt [SLC] [DevOps Advocate]3.91K 19th November 2025 0 Comments
How do I include an element to an extra view through code (QAction) run from a connector?
I do not want to restart the element when it moves.
Searching the documentation I could not find the answer.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 19th November 2025
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 19th November 2025 0 Comments
Hi Mieke,
The following code can be used to add the element to an additional view. Not sure if the element would not restart though.
IDms dms = protocol.GetDms();
IDmsView view = dms.GetView(“view name”);
IDmsElement element = dms.GetElement(“element name”);
element.Views.Add(view);
element.Update();
