How specify a DOM field descriptor as index field? (for both Double and String values)
Solved2.36K views16th August 2023DOM DOM Editor
Ladan Razeghi [DevOps Catalyst]1.09K 14th August 2023 1 Comment
While creating DOM, I need to set Client user Name filed descriptor as index so we avoid adding duplicated values. How can I do that?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 16th August 2023
Ladan Razeghi [DevOps Catalyst] commented 14th August 2023
Also can I use values from 2 DOM field descriptors to create new value and use it as index in another field but in the same section? e.g. IP:Port
Benjamin Hodžić [SLC] [DevOps Advocate]1.40K Posted 15th August 2023 0 Comments
Hi Ladan, as far as I know, you cannot change the default identifier of the Section and DomInstance objects (which is a GUID in the background). What you can try to do is use Exposers to easily find if there is already a DOM instance with a specific client user name to prevent adding duplicates.
https://docs.dataminer.services/user-guide/Advanced_Modules/DOM/DOM_examples/DOM_Invoice_app_example.html#readingfiltering-dom-instances
