how is the flow chart of a Protocol
Solved1.69K views24th April 2024internal flow
Ömer Eryaman [DevOps Member]723 23rd April 2024 0 Comments
right now I am struggling to understand the code, after various triggers and actions I am confused. I lost the overview. I found this Video (https://community.dataminer.services/courses/dataminer-connector-integration-http-basics/lessons/http-internal-flow-introduction-and-dataminer-processes/?hilite=internal+flow) but It's not really clear for me.
In this picture, I created my own flowchart. That's execute an HTTP-Request and store the Data in a variable.
How does the QAction execute if I didn't call it ?
It is having something in relation to the content PID in the session?
<Session id="200" name="createTokenKeycloak">
<Connection id="1" name="createTokenKeycloak">
<Request verb="POST" url="keycloak/auth/connect/token">
<Headers>
<Header key="Content-Type">application/x-www-form-urlencoded</Header>
</Headers>
<Data pid="204"></Data>
</Request>
<Response statusCode="205">
<Content pid="206"/>
</Response>
</Connection>
</Session>
Is there any flowchart or row how each Function get called?
Ömer Eryaman [DevOps Member] Selected answer as best 24th April 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 23rd April 2024 4 Comments
Hi Ömer,
A QAction always triggers on a certain parameter. See the following page in the documentation for more information: https://docs.dataminer.services/develop/devguide/Connector/LogicQActions.html#executing-a-qaction.
In your case the QAction probably triggers on a change of parameter 206?
<QActions>
<QAction id="10" name="Process response" encoding="csharp" triggers="206" />
Another possibility is working with an "after group" trigger (group 200) that executes a "run actions" action that eventually triggers the QAction that processes the response. This has the advantage that the QAction will also be triggered when no response was received from the device (i.e. timeout).
Ömer Eryaman [DevOps Member] commented 23rd April 2024
Thank you,
I just see I linked it to a button. But is there any possibility that if a parameter(param) changes, it can be a trigger to execute the QAction?
And is there any graphical flowchart for the executing of the code (like I did)?
Tom Waterbley [SLC] [DevOps Enabler] commented 23rd April 2024
If the ID of that parameter is present in the triggers attribute of the QAction, it will automatically be triggered when the value of that parameter changes.
I’m not immediately aware of such flowchart, but will check internally. In the meantime this maybe already helps you further? https://docs.dataminer.services/develop/devguide/Connector/InnerWorkingsIntroduction.html
Floris Cockaerts [SLC] [DevOps Member] commented 23rd April 2024
This page contains a few graphs that explain what’s being discussed:
https://docs.dataminer.services/develop/devguide/Connector/InnerWorkingsSLProtocol.html
Ömer Eryaman [DevOps Member] commented 24th April 2024
Thanks a lot I will check
