How can I temporary disable a CRC-check to locally reproduce a parsing issue in a serial driver?
Solved2.43K views27th January 2023Connector crc serial protocol
6
Michiel Clepkens [SLC] [DevOps Advocate]1.51K 27th January 2023 0 Comments
Hi Dojo
A user experienced a parsing issue on parameters 1305, 1306 and 1307. I want to reproduce the issue locally by using a serial driver and testing it with several inputs. As a consequence the CRC-value at the end of the response needs to change as well. Since this is not the core of the problem, I want to temporary disable this check to test if my fix works.
Can someone of the community help me with that, please?
Thank you in advance!
Kind regards
Michiel Clepkens [SLC] [DevOps Advocate] Selected answer as best 27th January 2023
Joachim Ally [SLC] [DevOps Advocate]1.64K Posted 27th January 2023 2 Comments
You can do this by altering parameter 6013, where Dataminer performs the CRC-check on the input. If you put the CRC-tag in comment as indicated in the screenshot, the CRC-check will not be done and you can debug the parsing issue easily.
After debugging and fixing the issue, uncomment the tag again, as the CRC-check is an important asset in the error detection in serial communication.
Kind regards,
Joachim
Joachim Ally [SLC] [DevOps Advocate] Posted new comment 27th January 2023
Michiel Clepkens [SLC] [DevOps Advocate] commented 27th January 2023
Hi Joachim. Thank you very much for your answer! Your suggestion does the trick. Much appreciated!
Joachim Ally [SLC] [DevOps Advocate] commented 27th January 2023
You’re welcome!
