Have element timeout event trigger a critical alarm for the element?
Solved4.26K views16th November 2021alarm severity Correlation rule
Jeff Douglass870 12th November 2021 0 Comments
Is there a way to have an element go RED and trigger a Critical alarm for the element in timeout?
Thanks
Jeff Douglass Answered question 16th November 2021
Jeff Douglass870 Posted 16th November 2021 0 Comments
Thank you all for the assistance. I will give these options a try.
