GetAgent() using DMS – Automation Script
Solved1.40K views23rd July 2024#automationscript Automation DIS automation scipt automation scripts
Baranisudha Murugesan [DevOps Member]1.19K 23rd July 2024 0 Comments
I want to find the agent id of my dataminer. I use GetAgent(id) now to get the views, services and elements inside DM now. But i want to make it generic without providing the agent id. Is there any method to find it?
Baranisudha Murugesan [DevOps Member] Selected answer as best 23rd July 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 23rd July 2024 3 Comments
Hi Barandisudha,
To retrieve the ID of the DMA on which the script is being executed you can access the following property: Engine.SLNetRaw.ServerDetails.AgentID.
More documentation: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Net.ServerDetails.html
Baranisudha Murugesan [DevOps Member] commented 23rd July 2024
I just have to initialize the ServerDetails() to get my agentId?
Tom Waterbley [SLC] [DevOps Enabler] commented 23rd July 2024
You don’t have to initialize anything. The property can be accessed immediately.
var agentId = Engine.SLNetRaw.ServerDetails.AgentID;
yes actually it works. Thank you
