Generic Syslog Receiver – Received Messages not stored
Solved2.51K views22nd March 2024catalyst syslog
Joerg Stumpf [DevOps Advocate]231 18th March 2024 0 Comments
Hi Dojo
We have a Cisco Catalyst that is sending syslog messages to DataMiner (10.0.0.0-9589-CU7).
I can see the messages in Stream viewer, but the Received Raw Messages Table is still empty.
I configured the IP address of the switch as accepted IP address in the Edit dialog of the element and as IP Filter in the General settings.
Do I have to configure the structure (layout) of the syslog message?
Is there any documentation of the connector?
Any ideas?
Thanks Dojo
Joerg Stumpf [DevOps Advocate] Selected answer as best 22nd March 2024
Joerg Stumpf [DevOps Advocate]231 Posted 22nd March 2024 0 Comments
Thanks a lot Ive!
Selecting UDP instead of TCP solved the issue !!!
