Generate Driver Help
Solved1.59K views25th August 2021
Stijn Declerck [SLC] [DevOps Advocate]824 25th August 2021 0 Comments
Hi all,
Is it still possible to generate a driver help in DIS?
If so, how can you do that?
Thanks!
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 25th August 2021
Maxim Bouckaert [SLC] [DevOps Member]179 Posted 25th August 2021 3 Comments
Hello Stijn,
This is still possible using the following tool:
Jan Staelens [SLC] [DevOps Advocate] Posted new comment 31st August 2021
Stijn Declerck [SLC] [DevOps Advocate] commented 25th August 2021
Hi Maxim,
At my side the ‘Plugins’ menu is disabled. What can I do to include the ‘Generate Driver Help’ option into that menu?
After closing the solution and opening the DIS settings, the ‘Plugins’ menu was suddenly available again.
Avatar photo
Jan Staelens [SLC] [DevOps Advocate] commented 31st August 2021
Several menu’s only show up if you’ve got the protocol.xml itself as the active document. Perhaps that was the reason?
