Generate correlation alarm when two specific alarms occur in an element
Solved2.80K views13th August 2024Correlation rule
Min Thant Aung [SLC] [DevOps Member]773 13th August 2024 0 Comments
Hello Dojo,
I am trying to generate a correlation alarm when I have two specific alarms on an element.
For instance, as shown below, I am trying to generate a correlation alarm when there is a Critical alarm severity on Param1 and Param2.
Below is the correlation rule, I am trying to test:
I tried to test with the OR condition and it works fine for me.
But when I changed to AND condition, the correlation alarm is not generated.
Is there something am I missing to apply?
Thank you for the help.
Min Thant Aung [SLC] [DevOps Member] Selected answer as best 13th August 2024
Catarina Grilo [SLC] [DevOps Advocate]3.69K Posted 13th August 2024 0 Comments
Hi Min,
Based on your screenshot, there are two separate alarms: one for "param 1" and another for "param 2."
These alarms will be evaluated independently.
Since your condition requires both "param 1" and "param 2" to trigger, the rule won't trigger. This is because each alarm will only meet one condition, not both.
Catarina Grilo [SLC] [DevOps Advocate] Answered question 13th August 2024
