Feed Output text from Automation Script to Text Input
Solved1.68K views19th April 2024IAS LCA
Sigan Kunai108 19th April 2024 0 Comments
I hope to find an answer about how to feed an output of Automation Script in LCA to Text Input ?
Is that available ?
Like I want to make when I execute the button and run the AS then feed the output to the Text Input ?
Sigan Kunai Selected answer as best 19th April 2024
Gilles Bara [SLC] [DevOps Advocate]7.17K Posted 19th April 2024 0 Comments
Does it have to be a text input feed? Or is the use case to display the output of the script somewhere in your app? If it's merely about displaying the value, I would consider using the text or html component and dynamically inject the output of the script.
The result will show the value of script output with key 'input' inside the component after clicking 'button 1':
Inserting it in the text feed is currently not possible, but you could use the script output feed everywhere where the text feed could be used, so if it's not to display the output value, you could directly consume the output and skip the text feed.
