Error connecting to remote debug
Solved1.63K views5th February 2024DIS remote debugging
Robin Becker [DevOps Member]1.42K 5th February 2024 0 Comments
I'm setting up remote debugging on a new computer and I'm getting an error when "Attaching" while trying to remote debug a connector. When clicking the "Test Connection" button in the DIS settings I get a success message and I've tried changing all the DNS names to the IP without success. The green plus in the DIS Inject window successfully uploads the dlls.
Error:
2024/02/05 11:38:49.769|Could not retrieve processes
System.Runtime.InteropServices.COMException (0x80040022): The debugger cannot connect to the remote computer. The debugger was unable to resolve the specified computer name.
at EnvDTE100.Debugger5.GetProcesses(Transport pTransport, String TransportQualifier)
at Skyline.VSX.ProtocolEditor.Toolwindows.ViewModel.InjectDllManager`2.RetrieveProcesses(DmaDebugInfo debugSettings, Transport transport)
2024/02/05 11:38:49.957|OnAttach_Executed|System.Exception: Could not retrieve processes, please check your settings. ---> System.Runtime.InteropServices.COMException: The debugger cannot connect to the remote computer. The debugger was unable to resolve the specified computer name.
at Skyline.VSX.ProtocolEditor.Toolwindows.ViewModel.InjectDllManager`2.AttachToProcess(String processName)
at Skyline.VSX.ProtocolEditor.Toolwindows.ViewModel.InjectDllManager`2.OnAttach_Executed(Object sender, ExecutedRoutedEventArgs e)
Robin Becker [DevOps Member] Selected answer as best 5th February 2024
Robin Becker [DevOps Member]1.42K Posted 5th February 2024 0 Comments
Solved it. Apparently it was the computer name in the "Debugger qualifier" field that my local client couldn't resolve. Exchanged it for the IP instead and it worked.
