Element IP in QAction
318 views2nd December 2025
Arbab Waheed [DevOps Member]111 2nd December 2025 0 Comments
I want to read Elements IP in my Connector using QAction. So far what I have seen is that the only way to achieve is by adding parameter and then set it and read it. Is that correct?
Bram Devlaminck [SLC] [DevOps Enabler] Answered question 2nd December 2025
Bram Devlaminck [SLC] [DevOps Enabler]922 Posted 2nd December 2025 1 Comment
Hi Arbab,
This is indeed done by defining an extra parameter.
More specifically, you'll need an "ip" or "pollingip" parameter as shown here in the documentation.
However, you don't need to set that parameter, it will be automatically filled in by DataMiner based on the data that you configured in the element wizard when creating or editing it.
Kind regards,
Arbab Waheed [DevOps Member] Posted new comment 2nd December 2025
Arbab Waheed [DevOps Member] commented 2nd December 2025
Thank you for the clariffication
