Element Connection Status
Solved1.61K views22nd March 2021
Julio Riambau [SLC] [DevOps Member]302 18th March 2021 0 Comments
Is it possible to retrieve the status of each of the connections in an element?
Thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 22nd March 2021
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 19th March 2021 0 Comments
In the general parameters of an element there is a “[Communication Info]” table. Maybe that one could be used to retrieve the status of each connection.
