Driver Smart-Serial with 2 http adicional connection dont execute session
Solved2.86K views16th July 2021
Juan Falcon [DevOps Member]350 10th June 2021 0 Comments
Hello
I have a driver Smart-serial by defaul with 2 aditional conexion the firt make a push of values in the port 5000 and the second it's for http requests on port 8080.
For some reason one element works well with all conections but wen i duplicate or create and other element the session do not run.
I'm using the tag (connection="N°") to  specify the conextion to use in the HTTP group.
The debug log show in the good element the start, prosessing and finish of group and the back element only start and finish without error and without content but is the same protocol.
Tanks
The code:
<Type relativeTimers="true" advanced="HTTP:HTTP Connection1;HTTP:HTTP Connection2" communicationOptions="makeCommandByProtocol">smart-serial</Type>
<Group id="114" connection="2">
<Name>getGeofences</Name>
<Description>GET /api/geofences/deviceid</Description>
<Type>poll</Type>
<Content>
<Session>14</Session>
</Content>
</Group>
<Ports>
<PortSettings name="HTTP Connection1">
<Type>
<DefaultValue>ip</DefaultValue>
</Type>
<BusAddress>
<DefaultValue>ByPassProxy</DefaultValue>
<Disabled>false</Disabled>
</BusAddress>
<IPport>
<DefaultValue>5000</DefaultValue>
</IPport>
<PortTypeSerial>
<Disabled>true</Disabled>
</PortTypeSerial>
<PortTypeUDP>
</PortTypeUDP>
</PortSettings>
<PortSettings name="HTTP Connection2">
<Type>
</Type>
<IPport>
<DefaultValue>8080</DefaultValue>
</IPport>
<PortTypeSerial>
</PortTypeSerial>
<PortTypeUDP>
</PortTypeUDP>
<BusAddress>
<DefaultValue>bypassproxy</DefaultValue>
</BusAddress>
</PortSettings>
</Ports>
Juan Falcon [DevOps Member] Selected answer as best 16th July 2021
Flavio Meneses [SLC] [DevOps Enabler]1.35K Posted 8th July 2021 1 Comment
Apparently this is an known issue in DataMiner version 9.6.13 (please check RN24348 ) and hotfixes were released to solve it.
Also, the issue is not present in most recent DataMiner versions (from 10.0), neither in version 9.6.12.
Hope this helps 🙂
Juan Falcon [DevOps Member] commented 9th July 2021
Hi Flavio, thank you very much with this confirmation, I really assumed that this could be the problem. your answer helps me with the next steps to take.
